rear end
Old May 13, 2007 | 09:15 AM
bigal's1991's Avatar
Car: 1991 camaro RS
Engine: currently swapping 5.3
Transmission: 4l60e
Axle/Gears: soon to be 4:11
rear end
will a s-10 rear end be a direct bolt in, into a 91 camaro v8? and does anyone know how many rmps a 91 camaro rs v8 auto(700R4) with 3:42's would run at 70 miles an hour?
Old May 14, 2007 | 03:23 AM
ede's Avatar
ede
Re: rear end
no not even close. it depends on what gear it's in. 1:1 would be around 3400
Old May 14, 2007 | 11:43 AM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: rear end
At 70 rpms should be 2200 in 4th (overdrive).
Old May 14, 2007 | 12:16 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: rear end
depends on the tire size...
Like ede said, the rear end housings have not much in common. The only rear end that will be a direct swap is another one out of a 3rd or 4th gen(slightly wider) that has the torque arm provisions.
you could fab up brackets to fit any other rear end in there but its not worth all the BS!
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
