the mystery filter
Old May 16, 2007 | 10:00 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
the mystery filter
After popping off the 2nd accumulator housing and seperator plate I noticed this little cone filter type deal on the floor and I have no idea as to where it goes.
Also while installing a new boost valve from the transgo kit, I managed to get it all up in there per the instructions and the retaining spring is seated in the grove, but the boost valve is like stuck, it wont come back down against the retaining spring like the original was. If and when I get it back together will the line pressure break it loose?
Old May 17, 2007 | 05:18 AM
mopfried's Avatar
Re: the mystery filter
There are two of them in the case part of the valve body. One goes into the rear of the valve body opposite the accumulator. There is a caged check ball in a passage on the very rear, the next non-bolt hole going away from the accumulator is where one goes. The other goes in on the front side in a passage on the very front on the same side the accumulator is on. I hope this helps.
Old May 17, 2007 | 08:53 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
sweet!! thank you! Was the one towards the front of the case
FormulasOnly
Oct 2, 2015 05:52 PM
Gordonr1973
Sep 29, 2015 11:59 AM
