tips on replacing transmission mount?
Old May 18, 2007 | 02:57 PM
suh_wheat_86305's Avatar
Car: 1986 Trans Am
Axle/Gears: 3.23 gears
planning to do this myself...
anyone willing to share procedure and/or tips?
1986 TA, 305, TPI, 4 speed, Auto... thumping noise at full throttle, gash marks in body pan directly above u-joint...
Thanks!
Old May 18, 2007 | 03:07 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: tips on replacing transmission mount?
easy to do. Put a jack underneith the tailhousing, drop the x member, take out the 2 bolts holding it on to the tranny. They are 15MM. Should be a 15 minute job.
Old May 18, 2007 | 05:59 PM
pierced1's Avatar
Car: 1990 RS
Engine: 3.1 V-6
Transmission: Auto-?
Axle/Gears: I dunno yet...
I will be doing this soon as well, looks fairly simple. Looks like you could change it without dropping the cross member. I found last week when working under it i was trying to get some leverage and put my knees against the tranny to push on and it raised up to the floorboard.....could you not slide it between the tranny and the cross member or is it not going to work that way if your trying to put in a new mount? I'm prob totally wrong about this....but thats the way it seems.
Old May 18, 2007 | 06:21 PM
Car: 1986 Trans Am
thanks, 86camaro383!
your knee exercise sounds scary... I think that is exactly what is happening to my tranny... there are scrap marks on the body pan, directly over the u joint. The only thing I can imagine is that the tranny mount is allowing the tranny to pull up that far. I hear and feel an unsettling thumping when I try to punch it from a stop...
Last edited by suh_wheat_86305; May 18, 2007 at 06:24 PM. Reason: Automerged Doublepost
Old May 18, 2007 | 06:48 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
dont for get the locktite and/or lock washer(s).. its a bitch when they come loose or you completely loose a bolt..
Old May 18, 2007 | 07:35 PM
pierced1's Avatar
Car: 1990 RS
Engine: 3.1 V-6
I cant give mine more than 25% throttle from a stop or it makes a very loud WHAP under the car...kinda scary....so i just have to have a light foot when driving it until i get it replaced. Which isn't always easy!!
Old May 19, 2007 | 05:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You can. Remove the bolt that holds the old mount to the cross member, then jack the tailshaft up slightly, unbolt the old mount at the tranny and remove, insert the new and bolt-up. Drop the tailshaft and reinsert the retaining bolt. Probably take you longer to jack the car up than to swap the mount.
JamesC
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
mizz0313
Aug 12, 2015 06:45 AM
