9 bolt swap to 10 bolt...will the brakes switch over?
Old May 26, 2007 | 10:59 AM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
I have a 9 bolt with the sh*tty 2.77 gears and im looking at getting a 10 bolt 3.73. however i dont want to lose my rear disc brakes. can i pull my discs off my 9 bolt and put them right on my 10 bolt?
Old May 27, 2007 | 06:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 9 bolt swap to 10 bolt...will the brakes switch over?
Originally Posted by StreetRoc85 350
I have a 9 bolt with the sh*tty 2.77 gears and im looking at getting a 10 bolt 3.73. can i pull my discs off my 9 bolt and put them right on my 10 bolt?
If both rears are discs, you can do what you suggest with the proper backing plate. If the 10-bolt is a drum, axel modification will be required.
JamesC
Old May 27, 2007 | 11:26 AM
Car: 88 IROC
exactly what kind of modification is involved? this sounds expensive......
Old May 27, 2007 | 08:09 PM
JamesC's Avatar
The mod is detailed on this site and isn't terribly difficult or expensive. I did, however, neglect to mention Ed Miller's new bolt-on modification.
https://www.thirdgen.org/forums/brak...drum-rear.html
JamesC
Old May 30, 2007 | 01:02 PM
Car: 88 IROC
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
Eric-86sc
Apr 3, 2016 03:52 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
