zoom clutches
Old May 31, 2007 | 01:30 PM
edman87k5's Avatar
Car: depends on the weather
Engine: several
Transmission: all manual
Axle/Gears: lots
zoom clutches
I will be replacing the clutch in my car soon. I have no idea what clutch is in it right now, it was there when I bought the car, I assume it is oe or stock replacement. I was considering replacing with a zoom high performance organic set. Anyone have any experience with these? Hold good on a stock motor? Last a while?
Old May 31, 2007 | 06:00 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
Re: zoom clutches
I'm not sure if the one I bought was organic, but I bought a complete clutch kit from advance auto for my 90 Firebird. The original had 160k on it, and was down to the rivets. I put the zoom clutch in and that car was terrible after that, even after a proper break-in. It was extremely difficult to get a good launch. It seemed to get hot REALLY fast. If you didnt get the launch perfect the first time, it didnt give a second chance. If you tried to launch too hard it would slip like crazy. The clutch may do ok on the street with an easy driver, but if your looking for real performance then I will say flat out that I think zoom makes garbage. My original 160K+ clutch that was down to the rivets held better than the brand new zoom clutch. If i ever buy another clutch it'll be ANYTHING accept Zoom.
Old May 31, 2007 | 06:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: zoom clutches
ooo, not what i wanted to here. ive got a zoom kevler faced clutch im going to try whan i get my car back together, i hope its better than that
Old May 31, 2007 | 06:27 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: zoom clutches
I had a Zoom Power Torque ( I think that was the model) from Advance Auto and it lasted about 3 weeks before I removed it and had Advance refund my money and labor costs.
It would either slip really bad or chatter. I then went with a Centerforce Dual Friction and loved that clutch setup.
I just recently put in a new clutch kit in my 88 Formula and went with a Hays Performance kit from Jegs for $245, comes complete with PP, Clutch disc, pressure plate bolts, TO bearing, and alignment tool.
I am very happy with this one.
Old May 31, 2007 | 06:43 PM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
Re: zoom clutches
Here is the listing from summitt:
http://store.summitracing.com/egnsea...115+4294840138
I was thinking the 5th down zzz30009
My car is a stock 91 rs305, nothing wild, but I want the clutch to last when I replace it.
Old May 31, 2007 | 08:27 PM
Zepher's Avatar
Re: zoom clutches
that is the one I had and didn't like it.
Old May 31, 2007 | 08:31 PM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
Re: zoom clutches
OK, might nix that idea!
Any other opinions?
Old Jun 1, 2007 | 12:44 PM
Zepher's Avatar
Re: zoom clutches
Centerforce Dual Friction $320 or so >Jegs
Spec Stage 1 or 2 $250 + shipping >thunder racing
Hays Performance Clutch $245 shipped >Jegs
Old Jun 1, 2007 | 02:38 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Re: zoom clutches
Yeah I complained to Advance too, and they told me to bring it back for a refund, but unfortunately when I put the Zoom clutch in I was also repairing my subframes and installing a full frame system, and after putting the trans back, I had to weld the cross member back in since I had ripped it out like 3 times. So it would have been alot of work to replace the clutch again. Instead I just stopped beating on it and started searching for another Bird. Now I got my 83 TA and I swear it will NEVER get a Zoom clutch of any kind.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
