built t5
Re: built t5
Replace it with something else.
Alternatively, baby it.
Of course, that all partly depends on your definition of "handle", and how well the motor is tuned, and how aggressive the driver is.
Re: built t5
never launch it hard from a stop unless you got some shitty worn out tires on it.
if you get good grip and try to launch hard you will ruin it
other than that...accelerating hard from a decent roll shouldn't really hurt it.
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
Re: built t5
you would need to replace nearly all the internals, and there are kits for it. The other issue would be the case, i've not heard its terribly strong :-x tbh it'd be cheaper to buy a 4+1 richmond outta summit than to beef up a t5
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
