t-56 swap bolt specs
Car: 1984 L69 Trans Am
It's an 83 T/A. Pulled the 305 and 700R4, gosh, has it been 12 years already?
Anyways, I have a 350 (2pc rear main) and t56 waiting to go in. I've done my homework and have all the parts..... except for the fasteners. What are the specs that I need?
I will need:
- trans to engine
- torque arm
- rear crossmember
- flywheel
- flex plate
I went to the dealer but they were totally clueless.
I will need:
- trans to engine
- torque arm
- rear crossmember
- flywheel
- flex plate
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: t-56 swap bolt specs
Yea, stealerships are notoriously retarded about that.
Bell housing to engine - 3/8"-NC, 1.5"long, grade 8. Use washers
Torque arm - which bolts ? TA to rear? TA clamshell? TA mount to tranny?
tranny cross member to frame- should be an M8 coarse. The threads are usually ripped out though, try drilling and tapping for 7/16"NC if you can. Or else drop in a 3/8"NC 1.25" long bolt from the top side, and use a nut underneath.
flywheel - buy these at a parts store, the MR gasket ones. They come in a neat little packet which comes with the little star washers. Use blue (or red) loctite.
Are you planning on using a flywheel or a flexplate with your T56?
Car: 1982 Trans-Am
ok, same as the flywheel, grab the MR gasket pack of bolts on the shelf. "Clutch bolts" it should be called. Those are crucial, the bolt has a shoulder that helps locate it. Again, loctite.
ambainb
Apr 25, 2016 09:21 PM
Hello, Michael
Aug 20, 2015 03:19 PM
