Aftermarket T56
Old Jun 14, 2007 | 02:54 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
Aftermarket T56
i have a aftermarket T56 in my 86 camaro. I am having a problem with the clutch pedal. One of my friends was telling me that i may need to use an adjustable T.O bearing or shim the bearing. Has anyone needed to do this that is running the aftermarket tranny. I am using all stock 3rd gen pedals and master along with lakewood scattershield and the adapter plate that bolts to it. i heard that using the plate brings the T.O out to far and needs to be adjusted closer to engage the pressure plate. Any feedback would be great. thanks
Old Jun 16, 2007 | 04:45 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
Re: Aftermarket T56
is the clutch engage 2 far out or in. i heard about problems with the 3rd gen pedals and the t56
Old Jun 16, 2007 | 10:17 PM
smokefan's Avatar
Re: Aftermarket T56
i didn't check the distance of the TO bearing when i installed it. a friend told me that might be my issue that i am having. i also have some play in the pedal itself so i just ordered new bushings for the pedal so i will see if that helps it out or not.
Old Jun 17, 2007 | 09:42 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: Aftermarket T56
what problem are you exactly having? not going into gear, grinding, ect ?
Old Jun 17, 2007 | 09:53 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Re: Aftermarket T56
Might be your pivot stud, when I went to a Centerforce clutch in my vette it was horrible until it was pointed out to me there was an orange peice of paper outlining the proper length of the stud, I bought an adj stud and helped a ton. Still not totaly happy with the clutch but it def engages way better after changing out the stud.
Old Jun 17, 2007 | 02:14 PM
smokefan's Avatar
Re: Aftermarket T56
the problem that i am having is when the clutch pedal is engaged i only have about a 1/2 of travel in the pedal before the clutch is fully disengaged. i am running a mcleod clutch using the t5 set up.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
