84 Firebird Transmission advice?
Old Jun 19, 2007 | 11:06 AM
liv2ryde's Avatar
Car: 1984 Pontiac Firebird Convertible
Engine: 2.8L v6 2bbl
Transmission: auto
I have an 84 Firebird 2.8 V6 2bbl automatic with overdrive. So I think I have the 700r4 transmission. Correct so far? It has 135K on it, I have no records of what has been done to it. I want to change the Trans Fluid and filter. Like the engine I would like to use Royal Purple fluid. Can you see any problem in doing so? I just want to give it good care. Thanks
Old Jun 19, 2007 | 11:37 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: 84 Firebird Transmission advice?
if its automatic trans then yes its the 700r4
its a gamble
change the filter and fill with new fluid and see what happens
thats really all you can do
how is the fluid now ?
does it smell like anything other than good tranny fluid ?
is it dark maroon or worse ?
if it were mine i would probably not mix in something crazy like purple unless i knew for sure that it has been changed on time all its life
if not then play safe and go with regular dextron mercon III
most 700r4 were lucky to see 130k or more
some will and do last longer though,
now and then
good luck
Old Jun 19, 2007 | 01:07 PM
liv2ryde's Avatar
Transmission: auto
The fluid looks healthy, not too dark, doesn't have a burnt smell. Drives and shifts as it should. I just want to make sure I am doing what I can to take care of it. So these transmissions are not known for going high mileage? What sort of problems are common? But I don't know if it has ever had work done on it. Maybe after pulling the trans pan I will know more about it's internal condition. Anything I should look for in particular?
Old Jun 22, 2007 | 09:38 AM
liv2ryde's Avatar
Transmission: auto
Can anyone tell me how many quarts of Transmission fluid I should pick up today with the filter? Thanks
Old Jul 3, 2007 | 11:09 AM
liv2ryde's Avatar
Transmission: auto
It took just under 5 quarts
Old Jul 6, 2007 | 09:21 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
i read somewhere that it should take about 9.5 ro 12 quarts to completely fill the transmission with trans fluid
Old Jul 7, 2007 | 11:28 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
That's if you remove the transmission and dump the torque converter...
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
E Rod
Aug 28, 2015 05:17 AM
formula_novice
Aug 18, 2015 08:48 PM
