High gear or overdrive problem?
Old Jun 19, 2007 | 08:07 PM
Kurt88IROC's Avatar
I am not sure what to search under. When i am at cruising speed in either D3 or OD (5.7 TPI w/ auto) and I let off the throttle, rather than stay at 2000 or less rpm (about 2000 rpm at about 55 mph in D3 and about 1500 rpm at same speed in OD)until I step on the gas again, the rpms drop about 300 rpm or so for a minute then go back up again ... almost like it is going into neutral and then back into gear again. Any ideas?
Old Jun 19, 2007 | 09:21 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: High gera or overdrive problem?
torque conv. is unlocking and locking according to the set parameters. sounds pretty normal.
somebody actually does exactly 55mph?
just kidding
Old Jun 20, 2007 | 09:03 AM
Re: High gear or overdrive problem?
Well, YEAH.. in a 35 mph zone....
junkcltr
Aug 2, 2019 11:12 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
jbd1969
Aug 17, 2015 07:06 PM
Fronzizzle
Aug 17, 2015 02:52 PM
