91 3.73 speedo gear question
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
i have a 91 z and in december i had 3.73`s put in. I just got it out and i need to know what speedo gear in need. i had 2.73`s. So if anyone know the actual speedo gears i need please help.
Re: 91 3.73 speedo gear question
I recently replaced the plastic speedo housing and speedo driven gear that had 45 teeth in my 84 z28 with a 3.73 ratio. Bowtieoverdrives.com has a calculator based on wheel/tire diameter, drive gear color, and drive ratio to estimate the best driven gear to use. Hope this helps
Transmission: t56
thanks but i don`t get the p metric crap or what not. i just need some part numbers and where too buy
Car: 1991 TRANS AM GTA
Engine: 5.7L TPI
Axle/Gears: 3.23 Posi
I used to have 3.73's in mine and the drive gear(smallest and on the output shaft), was the red one( cant remember the # of teeth) and the driven gear was green( dont remember the # of teeth on it either, sorry. But you can go to
this link and scroll down and it will tell you which ones to use and give you the part # as well. hth
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
