Does stock torque arm fit the T56 swap?
Old Jul 4, 2007 | 09:29 PM
RGV 89 GTA's Avatar
Car: 2001 SS/1989 GTA
I'm swapping the 700r4 from my gta to a t56 from a 96, can i re-use the torque arm or do i have to by an adjustable one? Also who sells the best crossmember for this swap as i dont have a welder to fab my own.
Old Jul 4, 2007 | 11:10 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Re: DOES STOCK TORQUE ARE FIT THE T56 SWAP
I'm in a similar boat, not sure if the autos and manuals use the same torque arm, I'm assuming they don't, but I'm pretty sure I can reuse mine, but I'm prolly not going to. as for crossmembers I like the spohn one personally.
Old Jul 4, 2007 | 11:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
same torque arm from 82 till 02. minor variance inthe early years about which way the lip of the torque arm faced. easily corrected by making sure your mount is facing correctly . both mounts will fit the clamshell on the tranny.
Old Jul 5, 2007 | 10:42 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Re: Does stock torque arm fit the T56 swap?
It will. My T56 came from a 1996 TA and it fit my '87 that was previously a 700R4 like clockwork.
I'd take a look at Skulte's crossmember, to see if it's smaller than Spohns.. I went with Spohn and the damn thing hangs almost two inches lower than stock. I have enough clearance problems already with the Eibach's on there, so Spohn is going away when I find a better crossmember.
Old Jul 5, 2007 | 11:17 PM
rjpbboi's Avatar
Arn't those pretty expensive though, I'm actually looking for a crossmember to fit my t56.
Old Jul 6, 2007 | 02:05 AM
Aaron_SK's Avatar
$150 for the OEM or retro, $200 for the LT version, so yeah they're pretty steep. Like I said, I haven't used them, but they look less over-engineered than the Spohn piece.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
InfinityShade
Aug 22, 2015 08:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
