Auto to manual swap, 1986 Camaro
Hello, kind of new to the boards, so I guess I should say hello to everyone, and thanks for all advice given to me in the future.
My car is a 1986 Camaro vin H carbed 305 700R4 that I just bought for $350.
So, down to business, my transmission is acting up with me, so I thought instead of bothering with it, I'll get a real transmission and put it in there. Without a lot of research, I have found I will need the brake and clutch pedals, the clutch hydros, the transmission itself, the shifter, and the console assembly from the junkyard, and the actual clutch kit. Now, can I get by using a used flywheel as it is, or do I need a new one? Am I missing anything?
My car is a 1986 Camaro vin H carbed 305 700R4 that I just bought for $350.So, down to business, my transmission is acting up with me, so I thought instead of bothering with it, I'll get a real transmission and put it in there. Without a lot of research, I have found I will need the brake and clutch pedals, the clutch hydros, the transmission itself, the shifter, and the console assembly from the junkyard, and the actual clutch kit. Now, can I get by using a used flywheel as it is, or do I need a new one? Am I missing anything?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Auto to manual swap, 1986 Camaro
you need a v8 trans from a f-body, the bell housing from an f-body. you can use a used flywheel but a new one is recommended and if the budget is there, get a billet flywheel, they tend to explode less, and your feet are a good thing to have. its not totally necessary, but better be safe then sorry.
Ok, another question, what would you guys suggest as a decent and cheap clutch kit/flywheel? I'm not going for much more power than stock, so it doesn't have to be rediculous. Links are good.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1986, 3rd, 86, auto, automatic, camaro, conversion, flywheel, gen, generation, hard, kit, manual, swap, transmission, transmissions
