Help- Rear End Noise
Old Jul 10, 2007 | 10:10 PM
86graybird's Avatar
Car: 1986 Firebird
Engine: V8
Hi all, I hope somebody can give me a clue what this might be.
I've got an 86 firebird, 305, 5spd and I've had this clunking noise that originally started as I'd be getting off a highway (generally as I was in neutral getting to a stop sign or a turn) while the drivetrain was hot (after being on the highway for 40 minutes or so). Changed the tranny fluid (it was original) and I don't hear/feel it so bad, but I'm pretty sure noise is coming from my rear end. Now as i'm on an exit ramp curving at about 25mph I hear like a rough clicking noise (almost like gears hitting each other?) and at slow speeds with my wheels only slightly turned I hear it too (doesnt seem like i'd be asking the posi clutch to do any work). Again, this is only when the drivetrain is hot.
Any suggestions appreciated.
Thanks,
Mike
Old Jul 10, 2007 | 10:48 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
Re: Help- Rear End Noise
Did you check the rear diff gear oil? Same thing happened in my 94.
Old Jul 10, 2007 | 11:11 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
drive the back up 2 ramps and take your diff cover off(looks like a pumpkin..) check for chiped teeth and your oil
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
