Not spinning
Old Jul 11, 2007 | 02:53 AM
Robb Knight's Avatar
Car: 1989 Firebird Formula 350 TPI
Engine: 5.7 350 TPI
Not spinning
I have an 87 TA 5.0 4bl. It was passed down to me from my father. For the longest he swore the thing was dual posi and I didnt believe him. Reason being that evertime I burned rubber only one side spun and thats the passenger side. Still he swore it was posi and said they both always spun for him. Anyways, One day we were messing with the timing on the car and he asked that I held the brakes and peeled/burned out. To my astonishment they both started spinning. I thought the problem was fixed and it had to do with the cars timing. Now since then I notice that the driverside doesnt spin all the time only sometimes. Now we still didnt get the cars timing to be perfect, but it is better than before. Now my question is, Is it really related to the cars timing or was that a coincidence and there is something else wrong that would cause this? Any and all feedback would be appreciated.
Old Jul 11, 2007 | 03:48 PM
Shagwell's Avatar
Car: projects.......
Re: Not spinning
Positive traction(posi) in no way shape or form has anything to do with the timing.
Usually open diff(non-posi) cars will spin the passenger's side and not the driver's, since there is more traction at the driver's tire due to the engine's rotational torque.
That said, the only proper way to know if it's a posi or not is to pull the diff cover and check, and it would sound to me as though this has probably never been done to the car, therefore it is probably over due a fluid change anyhow.
Old Jul 12, 2007 | 08:51 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Re: Not spinning
Unless things have changed, you can jack both rear wheels off the ground and turn one wheel with the car in neutral. If the other wheel turns the same direction, its a posi, if it turns the opposite direction, its not.
Sounds like its not, though.
Old Jul 12, 2007 | 10:58 PM
Engine: 5.7 350 TPI
Re: Not spinning
Im not the smartest person when it comes to cars. I know my **** for the most part, but terminology is what always gets me. Im the guy thats like "the thing under that other thing by the (fill in blank, for example exhaust manifold)". So excuse me for making an *** out of myself, but where is the "diff cover" because I've never messed with that on any car or I've simply never heard the name and just dont realize what your talking about. Im sure your gonna tell me something and im gonna be like "oh that thing" or "so thats the proper name" and if not I'll be happy that you taught me something new.
Old Jul 12, 2007 | 11:20 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
Re: Not spinning
ya my car does the same posi here and there it usually on new pavement...but it open carrier not posi hate it lol
Old Jul 12, 2007 | 11:22 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: Not spinning
the "diff" or differential (sp?) cover is the big semi round thing dead center between the axles. it has a couple (9-10 depending on rear you have) bolts running around the perimeter.
Old Jul 13, 2007 | 01:16 AM
xgtharo86x's Avatar
Car: 86' Trans am
Re: Not spinning
some people call it a pumpkin to
Old Jul 13, 2007 | 05:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Not spinning
Though the diff cover in the following pic (the silver thing) is after market, you'll get the idea:
https://www.thirdgen.org/forums/atta...-89-guides.jpg
JamesC
Old Jul 13, 2007 | 08:53 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: Not spinning
If you shock an open diff hard enough it will appear to be posi because there is NO traction at either wheel and both will spin.
What redlightrunner said is the quickest way to tell-----just jack it up and spin one wheel and watch the other.
Old Jul 13, 2007 | 11:33 AM
Shagwell's Avatar
Re: Not spinning
Things have changed. If the car happend to have a torsional type posi(it wouldn't have factory for the year) they'll spin opposite. Torsionals only lock down when shocked from the driveshaft.
like I said, pull the cover and look. I'm sure it needs the fluid changed anyhow.
and yes, I mean differential cover. The one between the axle tubes, located on the housing/pumpkin.
Old Jul 13, 2007 | 02:30 PM
xgtharo86x's Avatar
Car: 86' Trans am
Re: Not spinning
the way i do it at the junkyard is put it in neutral and have some 1 hold the opposite side and see if there is strain...if theres not its open diff...
Old Jul 16, 2007 | 01:32 PM
Shagwell's Avatar
Re: Not spinning
this still doesn't work for later-model torsional type posi units.
Old Jul 16, 2007 | 11:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Not spinning
There's a good chance it's a worn stock posi, that would explain it locking sometimes, but not always.
Remember, a posi is ~$400. Yikes eh?
And yea, there are cheaper ways, mini-spool, lincoln locker, used, etc - but you really get what you pay for here.
sheachopper
Jul 31, 2019 11:27 AM
gord327
Sep 29, 2015 10:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Denricci22
Sep 18, 2015 09:02 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
