lost 2nd gear after rebuild
Old Jul 11, 2007 | 05:02 AM
Keepin This One's Avatar
Car: 1988 iroc/2000 saab 9-5
Engine: 355 tpi/Roller cam
Transmission: 700r4/2800 stall,megashifter
Axle/Gears: 3;42
Done my first 700r rebuild,went great for a few miles.
Suddenly lost second gear,shifting manually,or auto.
If i tach it up to 4000 or so in 2nd it will catch for a moment.
Any ideas on where to start.?
Thankx for any info.
Old Jul 11, 2007 | 05:21 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: lost 2nd gear after rebuild
Band and servo.
Old Jul 11, 2007 | 11:24 PM
performabuilt's Avatar
Its likley you tore through the band lug in case particulary if you blocked the accums a NO NO , How is fourth shift
Old Jul 12, 2007 | 04:59 AM
Axle/Gears: 3;42
as of last night, not shifting into 4th.
She goes from 1st to 3rd,stays in third.
band lug? the lug that holds the 2/4 band in?
Im almost 100% sure i got in on correctly,
Can you give a little more info on the accums?and what to look for on the servo.
Old Jul 12, 2007 | 09:42 AM
Well when I say band lug I do not mean you didnt install it corectly. But that the pin pulled through the hole in the band , and this does sound more likley than the servos since since both would have to be bad.
When I say blocking acumulators I mean some people and even some shift kits will have you put spacers in the accum to restrict or eve stop there movment this will result in a very hard shift and will tear through the band pin hole unless its a reinforced type band, Othe things are billet servos if not used with the apropriate band
hectre13
Dec 11, 2023 08:14 AM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
backtothe80s
Sep 5, 2015 12:39 AM
someone972
Aug 30, 2015 12:52 AM
2QUIK4U
Aug 26, 2015 04:40 PM
