change shift points
Old Jul 15, 2007 | 06:26 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
change shift points
how can i change the shift point in my th350 when its in drive ?
Old Jul 17, 2007 | 06:49 AM
7Point4's Avatar
Car: 1990 Chevy 454SS
Engine: 454
Transmission: TH400
Re: change shift points
Gov. recalibration kit. Summit/Jegs/most anywhere. Pretty easy to do.
Old Jul 18, 2007 | 06:37 AM
Or, start by getting a new vacuum modulator. Get the one that's a small gold can and has a RED stripe; not a green stripe, not a pink stripe, not ANY other color but RED; and not the big black can type, either. SMALL GOLD CAN with RED STRIPE. Remember that. It's hard to know what vehicle to look it up for, so just keep looking up for different cars and opening the boxes until you find one with a RED STRIPE. I'd suggest looking up for something like a 71 Chevelle 454 with a Turbo 400, maybe that'll get it but who knows. Be ready to look up lots of different vehicles with Powerglide, 350, or 400; they all use the same modulator. Some will show a listing for some one of the variety or some other; just keep looking them up and looking in the box until you find one with a RED STRIPE.
There's a little screw inside the vacuum fitting. Adjust it inward to make it shift later and harder, outward to make it shift softer and earlier. Move it in ¼ turn increments until you get it where you want it.
Pop quiz: what color stripe should you be looking for?
Old Jul 18, 2007 | 08:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Uh, uh, the purple one! That's the one.
RBob.
Old Jul 18, 2007 | 10:33 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
Jegs part # 130-20234. Summit part # BMM-20234. Nevermind all that parts store hunting.
Old Jul 18, 2007 | 01:18 PM
7Point4's Avatar
Engine: 454
Transmission: TH400
Adjustable modulator mostly affects the part throttle shifts. To adjust wide open shift points you will need the gov. recal kit.
NAPA usually carrys the adj. modulator also. About 12-14$.
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
crazynights
Aug 21, 2015 06:53 AM
gwade12
Aug 8, 2015 08:17 AM
