I think I may have fried my trans
Old Jul 17, 2007 | 11:37 AM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
I had my 700r4 rebuilt three years ago so I didn't think it would go out this quick. Well anyway about 2 weeks ago it started acting up not wanting to shift so I played around with the tv cable and added a pint of trans fluid. That seamed to fix it. Then last Friday I took it to the track. It ran good the hole way there and the trans seemed to be working fine while racing (I have one heck of a boog off the line but I don't think that is the trans problem). I got my 5 runs in and I parked it and watched other people run. About 30 minutes later when I went to go home it didn't want to go in reverse it finally went in then it didn't want to go into 1st then it went in then it would drop in and out for about 100'. After I got out of the parking lot, it wouldn't go into overdrive and the lock up didn't work. I limped to Clinton and put in a quart of fluid. That got overdrive and the lock up back, but it still wasn't shifting right. I got it home and I changed the fluid the next day. It still doesn't want to go into gear when I first start it but it shifts right except it will gear hunt on the off ramp.
Any help with what to do would be appreciated.
Old Jul 17, 2007 | 10:32 PM
performabuilt's Avatar
Re: I think I may have fried my trans
When you changed the fluid what was in the pan ?
Old Jul 18, 2007 | 09:56 AM
z28z34man's Avatar
the fluid was a dark red, they weren't rely any big metal shavings on the magnet, but they was some light dusting on the magnet
Old Jul 18, 2007 | 11:11 AM
z28z34man's Avatar
if i do need a rebuild can i change some of my 84 internals over to the 87 and up stuff. and how can i tell if i have the 27 spline or the 30 spline under my impression they changed in mid year.
Old Jul 19, 2007 | 05:58 PM
z28z34man's Avatar
dose anyone have any clues
Old Jul 19, 2007 | 09:28 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The best way to check the spline count is to count them when the trans is out of the car. Instead of swapping the internals from a later year, buy a $100 core from an 87-92 model year and build it.
Old Jul 21, 2007 | 10:41 AM
z28z34man's Avatar
how are the patc 700 raptor rebuild kits(#13 Kit w/13 vain pump kit) with the torque drive upgrade and the 5x power raptor lockup converter upgrade
http://www.700raptor.com
BRoss99
Aug 10, 2025 05:08 PM
chazman
Aug 28, 2018 03:25 PM
Hawk312
Aug 22, 2017 08:55 PM
chazman
Aug 22, 2015 02:01 PM
Hello, Michael
Aug 20, 2015 03:19 PM
