Rearend problem
Rearend problem
I had the back of my car jacked up yesterday and I noticed that when I turned the wheels by hand there is alot of play in between the wheels. When I turn one a second later I will hear like a clunk and then the other wheel will catch and turn also. I can also feel it when I let off the gas and hit the gas again I hear the clunk and then the car will take off. I have the borg warner rear end. Is this a serious problem or does something inside the rearend just need tightening? Thanks for you help.
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: Rearend problem
you say borg warner is this the 9 bolt if so i've only seen a few of them and never heard anything good just change it out for a cheap easy to find 10 bolt newer is better they swich from a 26 to a 28 spilne in the later year some where around 86-87
