Rear end from another vehicle help?
Old Jul 17, 2007 | 10:39 PM
Liquidsteel's Avatar
My camaro is a 1990, with the stock rear end.I want a 3.73 rear end, i just want to get 1 out of another car, but i'm not sure what vehicle or year it would have it in there. Would a blazer or a S10 around that year have that gear?
Old Jul 17, 2007 | 10:52 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Rear end from another vehicle help?
Some 4 cyl trucks had 3.73 or even 4.10 gears. 82 and up are the choices I believe..
Old Jul 17, 2007 | 11:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The gears and carrier can be pulled out of another 7.5" 10 bolt and put into yours. Your 1990 will have 28 spline axles so you'll need to find a newer carrier that also uses 28 spline axles. Previous to 1990, the 10 bolt diffs use 26 spline axles. You need to be also aware of the gear series. The smaller number ratio gears such as 2.73 etc are a 2 series gear. The higher number ratio gears are a 3 series. You can't put a 3 series gear on a 2 series carrier.
As for the entire diff, no, you can't pull the entire diff out from under an S10 and put it into a third gen. It's the wrong width and only third/fourth gens have a casting to mount the torque arm to the diff.
Old Jul 18, 2007 | 12:25 AM
I just want to take the whole rear end from another vehicle and swap it with mines.
Old Jul 18, 2007 | 12:53 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Then you need to find a rear from a thirdgen F-body. You could use a fourthgen rear if you were willing to put up with a slight difference in width.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
