Non Lock up converter mods?
Old Jul 19, 2007 | 07:31 PM
jonarotz's Avatar
Car: 91 Z28
I have a 3000 stall non lock up converter installed on my 700R4. Ever since I installed it I have been getting a loud rattling noise. I removed the check ball from the front of the input shaft. I also installed the Trans go non lock up valve. I noticed that when I installed it there was quite a bit of movement of the valve in the bore. I suspect that this may be the problem. It only seems to do it when I am at a stop and take off under light to moderate throttle. I guess my question is, is it imperative that I use the non lock up vlve in the pump? Could I just install the OE valve and spring and run it?
Old Jul 20, 2007 | 07:36 AM
jonarotz's Avatar
Car: 91 Z28
Re: Non Lock up converter mods?
Wow! Nobody here has installed a non lock up converter?
Old Jul 20, 2007 | 03:16 PM
jonarotz's Avatar
Car: 91 Z28
Problem solved. Mods please remove.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
Jake_92RS
Aug 17, 2015 09:42 AM
