How to question - remove shifter
Old Jul 21, 2007 | 12:15 PM
90 GTA Black's Avatar
I've decided to keep the B & M shifter but use the stock leather shift ****. Problem is the threads are too large on the shifter. I have a machinist friend who will turn down the threads to match the the stock threads - I just have to pull the shifter. I have already removed the top 4 bolts but it seems like something else is holding it in. Having never done this on a 5 speed, I was looking for some pointers.
Old Jul 21, 2007 | 01:45 PM
toms84ss's Avatar
Re: How to question - remove shifter
There is a plastic cup the base of the shifter sits in. It will just pop out if you pull on it hard enough.
Old Jul 21, 2007 | 11:08 PM
I don't see a plastic cup. It looks like the base is siliconed to the top of the transmission. I tried pulling but it is solidly in place.
Old Jul 21, 2007 | 11:13 PM
toms84ss's Avatar
The cup is under the shifter. The silicone is the gasket. It will come off. You can try prying it up. But be careful, its soft aluminium. If you have the four bolts out, nothing else is holding it in.
Old Jul 22, 2007 | 12:15 AM
Thanks! That worked. It came out fairly easily once I knew that it was just silicone holding it in. Now off to the machinist!
Old Jul 22, 2007 | 05:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The OE leather-covered shifter ball fit the threats of my B&M perfectly.
JamesC
Old Jul 22, 2007 | 10:36 PM
I wonder why mine doesn't. I bought it from GM - maybe it's not the right one.
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
