which atf do you use with your shift kit??
Old Jul 25, 2007 | 02:21 AM
Red92Bird's Avatar
Car: '92 firebird
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 10 bolt 3.42 gears with eaton posi
searched for a good hour and found so many conflicting answers im frankly a little confused.
i just purchased a b&m transpak for my 700r4. when using the firmest shifting version of the kit they recommend the b&m trickshift atf. ive heard quite a few people say to stay away from it.
so my question is, which atf would be best for me to use. ive heard dexron 2,3 as well as type f could all work. i plan on driving this car mostly as a daily driver with some weekend track time.
thanks guys
Old Jul 25, 2007 | 11:57 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: which atf do you use with your shift kit??
They want you to use TrickShift so that they can get their hands on your money. Just use any regular old Dexron ATF.
Old Jul 25, 2007 | 07:52 PM
toms84ss's Avatar
Valvoline Dexron 3 and change the filter once a year.
Old Jul 25, 2007 | 10:30 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
better yet...get a transgo shift kit and get rid of the b&m one. then get some regular dexron atf(as previously stated) and go to town
Old Jul 26, 2007 | 07:21 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Dexron is chevy fluid. Type F is ford fluid, and a little thicker which yeilds higher pressures and a more firm shift. Trick Shift is actually a little thicker than Type F. The diffrences are SMALL at best. Pick 1 and stick with it, dont mix them. Let your wallet make the choice.
The TransGo kit is the better choice in shift kit
Old Jul 26, 2007 | 04:05 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I run dexron with my transgo.
Old Jul 26, 2007 | 04:13 PM
Pro Built Automatics's Avatar
Go with the "modified" TransGo Performance Shift kit. You will be better off in the long run. If you are going to stay with the B&M, then "DO NOT" block the 2nd gear accumulator, otherwise you will have brutal 1-2 part throttle shifts. Call me if you have any questions.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
