what 1/4 mile time drop when changing converters?
Old Aug 1, 2007 | 12:34 AM
89IROCZZ4's Avatar
I know that ls1 cars can drop over half a second with the right converter - is this true for the mighty 305 tpi as well? What have you all seen?
Old Aug 1, 2007 | 08:27 AM
Shagwell's Avatar
Car: projects.......
Re: what 1/4 mile time drop when changing converters?
With a basically stock car with minor bolt ons, you probably won't see 1/2 second. At the same time a car with a high powered engine could easily see over 1/2 second with the appropriate stall speed vs a stock converter.
A good converter is a key ingredient in a fast car. The big thing is that the appropriate stall varies per application.
All things considered a converter is far from the last thing I'd do for performance, but not at the top of the list for a mild street car either. There are many other things to do first that will give you more bang-for-your-buck.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
