4L60 false neutrals
Old Aug 1, 2007 | 05:54 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
4L60 false neutrals
this ones for you guys that know your transmissions...
I am having an issue with this performance built gearstar transmission 17,000 miles on it.
problem:
while driving mildly aggressive or ***** out manual shifting from second to third or while in automatic mode it appears I am loosing line pressure and its in neutral for a split second on the 2 to 3 shift.
I am not sure if third is coming in and going right out or if in fact it never engages.(very difficult to tell as i have a 3000 stall and it pulls like a bear in any gear) let me clarify that it is not slipping its just in neutral like i put the lever in neutral while driving. This transmission does not slip. The gears when changing are aggressive and tires chirp. high 7's in the 1/8 mile is what the car runs.
It has done this 6-8 times in the last 3000 miles or so. I have adjusted the linkage on the shifter and that did not solve it. tranny fluid is not burnt and level is o.k. I have ruled out the t.v. system and governor system based on how they work. If i am wrong please tell me.
what do i begin to look for such a problem and can you guys recommend a book with the info about how this tranny works so i don't have to depend on other people to solve my problems(as in where i bought it) they have been less than helpful over the last 18 months.
Old Aug 1, 2007 | 07:41 AM
Pro Built Automatics's Avatar
Re: 4L60 false neutrals
See what happens if you leave the lever in 4th gear (OD), not 3rd gear (D). It should change somewhat, if not solve it.
Old Aug 1, 2007 | 09:27 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
thats not the route i want to go and heres why...
the transmission is setup to shift manually at the track and when driven aggressivly. the shift points are set by the governor to shift at 4500rpm. my shifts need to be at 6000rpm. I really need to dig in and see why this is happening and i am ready to do so even if the tranny has to come out. I have been down the governor road and manually shifting is what i want it to do.
what need to be replaced to cure this? th350?
Old Aug 1, 2007 | 04:56 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
leaving in overdrive provides the same situation.
I replaced and recalibrated the governor with no avail... this thing is under warranty please help. should I send the complete unit back or request a new valve body???
Old Aug 2, 2007 | 05:52 PM
If you want 6,000 rpm automatically, you will need a Corvette valve body, and matching Corvette light weight governor. Find out what Gearstar uses for the 3-4 clutch pack here? and what Shift kit (if any) they use.
Old Aug 2, 2007 | 08:06 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
the shift points are not my concern read above.
alto redline racing frictions and band
transgo reprograming
gearstar full race shift kit
300m hardened steel shaft and hardened expanded capacity drum
corvette servo
13 vane pump
high load sprag
.500 boost valve
monster sunshell gear
hardened steels
extreame duty springs and sprags
expanded capaciy direct clutch drum power pack
overdrive 4 cluch power pack
expanded capacity foward clutch drum power pack
sonnax 3-4 superhold
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
92camaro350cci
Oct 14, 2015 09:29 AM
RedLeader289
Sep 23, 2015 06:50 AM
PeteK825
Sep 22, 2015 10:47 AM
Stroopwafel
Sep 11, 2015 06:38 AM
