just picked up a posi rear have some questions
Old Aug 6, 2007 | 08:00 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
i just bought a posi rear and he says it ether haas 2.73 gears or 3.73....did they even make a 2.73 posi...well im puting it in thiss weekend and seeing if it changes my speed to tell...if it is a 2.73 wut is the best gear set i can get for it i heard the carrier is bigger then other ones...its a new rear bought about 6 months ago from a speed shop....thanks
Old Aug 6, 2007 | 08:12 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: just picked up a posi rear have some questions
Check the ratio before you install it. 99 44/100% sure it is a 2:73 and yes they came with a limited slip (RPO G80). Very few 3rd gen cars had a 3:73 ratio (83-85). Hell of a speed shop if they could not tell you the correct ratio.
Old Aug 6, 2007 | 09:15 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
What are the numbers on the ring gear, (xx:xx)? This will tell you the ratio. The 2.73 lsd would be much more common, as a 3.73 lsd was only offered for a limited number of years. If it is a 2.73 carrier, the highest numerical gear you could get would be 3.08, although you could run a spacer and higher gears.
Old Aug 7, 2007 | 05:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's how to determinne what ratio the rear is (jerk the diff cover and look): numbers are stamped on the ring and pinion:
41 : 15 = 2.73
41 : 14 = 2.93
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
