3.23 to a 3.73 rear end w/ t56
Old Aug 9, 2007 | 07:08 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
i recently put a t56 with the .5 6th gear in my car. i have a 85 camaro with a 3.23 rear end gear. the gear is on it's way out and i'm looking to upgrade. what is the best option for a rear end. can i simply put a 3.73 ring and pinion in place of the old 3.23 ring and pinion? any ideas on what else to do.
Old Aug 9, 2007 | 09:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 3.23 to a 3.73 rear end w/ t56
Yes you can, but i'd go up to 4.11's if it were me. That .5 top gear will make for a nice cruiser even with DEEP gears.
Old Aug 11, 2007 | 03:36 PM
n8sz28's Avatar
Car: 85 camaro z28
thanks for the idea. would it be better to get a new ring and pinion and install it or just look around for a whole new rear end assembly with a 3.73 gear ratio. the backlash is what sounds like its tricky to put the new ring and pinion in.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
Numbah-1
Sep 12, 2015 08:57 PM
