Bell housing
Old Aug 13, 2007 | 04:26 PM
dst80944's Avatar
Bell housing
Does anyone know if the bell housings from v6's and v8's are the same? I'm collecting parts for my 5 speed swap. Thanks
Old Aug 13, 2007 | 05:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Bell housing
No, they're not. A V6 bellhousing will not fit a V8 engine, and vice versa.
Old Aug 13, 2007 | 05:49 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Bell housing
As a matter of fact, the 5 speed transmissions themselves are not the same either. Don't use a V6 transmission for your V8 swap. You can use a V8 transmission with a V6 as long as you use a newer clutch disk.
Old Aug 13, 2007 | 05:54 PM
dst80944's Avatar
Re: Bell housing
Thanks, I already have my transmission from an 85 IROC I had. That part I knew.
Old Aug 13, 2007 | 06:06 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: Bell housing
You never can tell which way people are swapping these days...
Plus, you only have 7 posts so I wasn't sure how much info you already had.
Just for extra info, if you keep watching these boards, you can get your swap done cheap. I bought my V8 T5 swap complete for 500 bucks from here! I got everything, including the crossmember and the pedals/hydraulics strapped to a pallet. Even the flywheel and old clutch kit came with it!!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
