LS1 Driveshaft ID
Old Aug 15, 2007 | 01:30 PM
h1-vltg's Avatar
Car: 91 Camaro Z28
Engine: LS3
Transmission: 6 Speed
Axle/Gears: 3.71
LS1 Driveshaft ID
I have a 1991 Z28 with the 5.7l. I picked up an LS1 DS and after reading all the threads I know it is a direct fit, but...
I just got a call from my mechanic and he told me that the DS is about an inch short? Is that possible/correct? Did I pick up something other than an LS1 DS?
Is there a part number stamped on the DS that can tell me what I have?
Old Aug 15, 2007 | 03:42 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: LS1 Driveshaft ID
Nothing stamped. I'm guessing it doesn't have the sticker on it anymore?
http://www.eecis.udel.edu/~davis/z28...1_partnum1.jpg
The LS1 shaft has a distinctive yoke that should be easy to id..
http://www.eecis.udel.edu/~davis/z28.../LS1_yoke2.jpg
Old Aug 15, 2007 | 03:54 PM
h1-vltg's Avatar
Car: 91 Camaro Z28
Engine: LS3
Axle/Gears: 3.71
Thanks I'll look when I get a chance and compare pics.
Old Aug 15, 2007 | 04:21 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Did you put the drive shaft that was in the car and compare it to the alum drive shaft??
Old Aug 15, 2007 | 04:45 PM
h1-vltg's Avatar
Car: 91 Camaro Z28
Engine: LS3
Axle/Gears: 3.71
No, I haven't pulled the DS in the camaro out to compare with the Aluminum DS. I was paraphrasing what the mechanic told me over the phone. He said when they held the Aluminum DS next to the DS in the car, the aluminum DS was about one inch shorter.
Old Aug 15, 2007 | 05:08 PM
wanta427's Avatar
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
I installed an LS1 aluminum shaft in my 91 and it's about 3/4" shorter than the stock steel one . 3 years no problems .
Old Aug 15, 2007 | 06:16 PM
novatuc's Avatar
Car: 1984 Trans Am
I believe the driveshaft is shorter but the yoke is longer due to the big collar thingy.
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
