overdrive ????'s
Old Sep 9, 2007 | 04:37 PM
schmeck11's Avatar
Car: 82 TA
Engine: 305 swap 350 swap 383
Transmission: 2004r
Axle/Gears: 3:73
overdrive ????'s
just finished a engine swap and tranny swap in my 82 ta. tranny is a 2004r from BTO. it shifts fine through all the gears and downshifts fine, but my problem is minimal throttle doing anywhere from 25-40 MPH. to cruise down a residential street at that speed requires next to no thorttle becasue the tranny shifts into overdrive and it will start to chug.
my question is should it shift into overdrive this soon? if I drop it into 3rd it runs at about 14-1500rpm and has good throttle response then. any suggestions?
Old Sep 10, 2007 | 01:29 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: overdrive ????'s
contact BTO immediatly and discuss this with their tech's they will know exactly what you need.
Old Sep 10, 2007 | 12:33 PM
schmeck11's Avatar
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
I did contact BTO today and they told me around town (i'm assuming under 45) I should not have the tranny in overdrive, I should keep it in third. does this sound right? it is a 200r4, do the 700r4's have this issue? seems like that's the point of the automatic, put it in drive and go. unless it's because it's pressure driven vs. computer controlled shifts? any comments?
Old Sep 11, 2007 | 12:02 AM
yeah if you have it pressure driven then only put it in overdrive above 45MPH, if computer driven it is supposed to be fine inOD. the pressure driven design should let it upshift at lighter throttle pressures causing the early OD shift.
Prodigious
Nov 7, 2020 09:23 AM
1992Z28!
Nov 19, 2015 07:33 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
wisemanz28
Sep 20, 2015 01:26 PM
84 TA NV
Sep 6, 2015 08:02 PM
