Fluid for T-5???
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
Fluid for T-5???
I'm wondering what most of you guys on here are running in your T-5 trannies. If you have any suggestions as to what i should run in mine. just let me know. I've heard that you can run oil in them?? is it bad or better for tranny life?? any help and insight would be appreciated.
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: Fluid for T-5???
dextron mercon for GM's
Car: 1986 Iroc-Z
Any opinions on using gear oil or oil in the tranny?? i knew about the dextron mercon... i forgot the names... i've been runnin that for a while... a buddy of mine that drag races said that most guys put oil in thier T-5's. i was just asking if anyone here has any positive comments about it.
on a world class unit I've heard gear oil is hard on the dog ears or something like that and can cause premature wear on the nylon synchros ... On the non world class I can't remember what gear oil hurts but I remember something about it.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
stick to the dex.. i run valvoline full synthetic ATF dex IV or something like that.. not sure on the exact name..
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
On the '88 and newer world class T5's, use ATF or synthetic ATF only. For the older non world class T5's, you can use 90 weight gear oil, or ATF.
HoosierinWA
Oct 7, 2015 10:15 AM
