couple questions regarding options on my car...
Old Sep 18, 2007 | 01:12 AM
LVZ2881's Avatar
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
car = '88 IROC 5.0l tpi, 5 speed
did irocs come standard with aluminum driveshafts, using the rpo decoder, my car came with one....
also, I do not have the G92, and I have the 3.07, posi, and aluminum drums, do I have the 9 bolt or 10 bolt rear??
Old Sep 18, 2007 | 01:48 AM
Brother Al's Avatar
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
Re: couple questions regarding options on my car...
RPO J42 is the aluminum drums, RPO JG1 is the aluminum driveshaft, as for your axle, its likely a 10 bolt but all you gotta do is count the bolts on the rear axle housing.You might be lucky and have a Dana 44 that someone added...
Old Sep 18, 2007 | 01:53 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
'88 seems to be a year GM put a lot of aluminum driveshafts in the cars as stock equipment. After that they get rare. But it was optional, not standard. I'm 99% sure you have a 10-bolt, and it has 3.08 gears.
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
