Wheel Studs
Old Sep 20, 2007 | 03:49 AM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Wheel Studs
I recently just put moroso 1/2 inch wheel studs in my axles. Put my prostars on and the lug nuts went on pretty easy. When i went to take them back off the lug nuts were REALLY tight. Ended up snapping off three studs. How does this happen with brand new hardware and 1/2 inch studs. I would like to know how it happens so it doesnt happen again with new er studs
Old Sep 20, 2007 | 07:36 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Wheel Studs
did you use the old lug nuts ? stock wheel studs are metric as are nuts . close to 1/2 in. but not quite . stock wheel studs are 12x1.5 [ i think ] . sounds like thats the problem .
Old Sep 20, 2007 | 12:17 PM
a/fool's Avatar
Car: 78 Z28
Transmission: 3500/th350
Axle/Gears: 5.13
Re: Wheel Studs
if you used the correct nuts with the studs a little bit of anti-seize couldn't hurt.
Old Sep 20, 2007 | 12:34 PM
Car: 91 Camaro RS
Engine: Small Block
Re: Wheel Studs
I used all new hardware, and brand new 1/2-20 shank style lug nuts on the 1/2-20 studs. Same as the fronts except all 7/16" and their fine. I also used anti-seize.
Old Sep 20, 2007 | 01:15 PM
UNCLE TOM's Avatar
Re: Wheel Studs
if they were the correct size as you say , there is one thing that could be the problem . many times chrome lugnuts get chrome inside on the threads . its always a good idea to chase threads with a tap . i say this because i had a damaged stud on my truck . chrome is much harder than steel and can gall the studs in a heartbeat . sounds like that happened to you . good luck !!!
Old Sep 20, 2007 | 02:06 PM
Car: 91 Camaro RS
Engine: Small Block
Re: Wheel Studs
yeah more than likely thats what happened. I installed the lugs on the other wheel and they all went on perfect. Probably just got three bad lug nuts. $hitty cause now i'll have to replace 3 more studs. Oh well, you gotta love a chevy. They are the best!
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
