tv cable question
Old Sep 22, 2007 | 09:21 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
tv cable question
ok i just swaped from tbi to carb. before when i had the bracket connected to where it is soppused to be, the tv cable was a little tight with the throttle closed. when i changed intakes and all i had to move the bracket up to the second bolt hole on the drivers side. and moving that forward created a lot of play in the cable. so my question is, is it soppused to be tight wheb the throttle is closed? i just need to get it close so i can drive it somewhere and have them make it right.
Old Sep 22, 2007 | 12:08 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: tv cable question
Did you get a Carb TV cable or still using the TBI one. Im not sure but you may need to check on the differences. What bracket are you using?
Old Sep 22, 2007 | 05:17 PM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
If I am not mistaken I was informed that with the throttle closed ,there should be 1/4 to 3/8 of and inch pull on the tv cable. The thing is the best adjustment is with the throttle in the WOT. It should be adjusted to as tight as possible with the throttle in the WOT position. I have Lokar adjustable cables and what I did was jam the throttle at WOT and use the fine adjustment on the TV cable to get it tight. You do not have this fine adjustment with stock cables and it is a nice feature. They say you should not be able to pull the TV cable out any at all at WOT . I noticed a difference in shifts even if I was able to pull it out between an 1/8 and a 1/4 inch at WOT.
Old Sep 22, 2007 | 09:31 PM
yeah i am using the stock braket just moved it forward as i said above. with it right now it won't "self adjust." and i can pull it about an inch when it is at wot. i will try to space it out so there is little to no extra at wot. thanks for the quick replies.
Old Sep 23, 2007 | 12:00 AM
Mikz86TA's Avatar
Then the bracket needs 2B farther back towards the Firewall. This will shorten the outter sleeve and draw more cable out. Then it will click out on the proper adjusting procedure. www.TVMADEEZ.com and go to the TV 101 section. Very descriptive and easy to understand.
Old Sep 23, 2007 | 02:36 PM
then if i do that, the throttle does reach
Old Sep 23, 2007 | 09:29 PM
Mikz86TA's Avatar
Does your throttle open all the way when flooring it form the inside of the car? Ck that 1st. Youll want to be sure that the acceleraor pedal operation is proper 1st
Old Sep 24, 2007 | 11:07 AM
yeah where it is now, when i floor it from inside it opens all the way up.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
