700r4 ownt down shift
Old Sep 23, 2007 | 05:36 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I have just got my car going and I am having a problem with the tranny. Driving normal the transmission shifts fine but if you go WOT the car stays in the gear that its in it wont down shift. I have a 355 with a 650 mighty demon and a adjustable throttle/tv cable bracket. Do I need to adjust my TV cable ??
Old Sep 23, 2007 | 08:46 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Re: 700r4 ownt down shift
Yeah, try and adjust it.
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
yes
Old Sep 23, 2007 | 09:05 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
You need a correct TV Base Bracket (one for Holley works on a BG) AND a correct TV Throttle Bracket (one for Holley works but needs a notch). I can get pics tomorrow of mine. The cable should start far enough back and the pull of the innder cable should be such that the TV plunger inside the v.body bottoms out. This is what causes that ratcheting out at WOT when initially setting the TV as per GMs instructions.
Old Sep 24, 2007 | 09:27 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I have the correct brakcet from csr with the adjustable throttle and tv cable. I and I believe I adjusted the tv cable right. All I did was hit the button push the tv cable back to the firewall and then hook it up to the carb and make the throttle go to WOT and the tv cable adjusted itself with the clicking.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
