how does the 9 bolt work?
alright i just picked up a 9 bolt with 345 gears and im just goign through putting new bearings and i have an eaton posi and a auburn but i didnt seem how this one works no springs is it a full posi pretty much a mini spool? or is there more to it on the inside and is a 100 bucks good for only needing break lines its a pretty clean rearend and all? how will it match up to my 10 bolt thats in my car (open 3.08).
Re: how does the 9 bolt work?
It works pretty much the same way as the others; the only difference is the friction element is brass cones, instead of plates.
Yes it's pretty much a bolt-in.
You might have brake issues, but that would depend on which brakes you have now, and which are on the 9-bolt.
The 3.45 was only in some years of 305/5-speed w/G92 cars. Not a whole lot of those in the world. Probably one of the best all-around ratios for a TPI motor, at least a near-stock one, as 3.7x tends to be too much, without some engine mods to help it breath freer at higher RPMs. $100 is a GREAT deal, if you don't have to do too much to it.
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
if you need rotors let me know i have some as i just did a swap to a 10 bolt
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
