Bellhousing Bolts and stuff
Old Oct 2, 2007 | 06:02 PM
Benny K's Avatar
Car: 91 Z28
Engine: TPI 350
I do an auto to WC T5 manual swap on my 91 L98 Camaro and since I'm in Switzerland I have to gather parts from everywhere...
What are the correct bolts to connect the tranny with the bellhousing? size and length...and what is used to secure them (I cannot go into the next shop and buy bolts like that since we have metric bolts everywhere..I got to know exactly what bolts I have to order )
Can I reuse my bolts from the th700r4 to connect the bellhousing to the engine?
Will the original auto-Starter work with an OE flywheel?
Thank you very much...
the search option did not work...did not show any results even with keyword "flywheel"
Old Oct 2, 2007 | 06:42 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: Bellhousing Bolts and stuff
you can use the same bolts to to connect the t-5 to the motor as you used for the auto.
i'm not sure but i think you can reuse your starter as well.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
jtwoods4
Sep 3, 2015 05:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
