trans woes
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
trans woes
went to track last night and had probs right away,wouldnt shift into 3rd or drive at wide open throttle unless i let off gas.adjusted cable seemed to fixit,went 2 rounds no prob ,but i was running a good 1 seconds off what it normaly runs? then while driving it home i got bout 30 miles from track and it was jumping back and forth from overdrive to 3rd ,few miles later motor was reving higher then normal in 3rd, then boom sound and no gears at all and a lot of noise,just had a new flexplate installed a couple weeks back, any ideas on this? and im kinda thinking a converter prob but im not sure just a guess that maybe my prob weeks ago wasnt a flexplate but poss a converter failing? what is symptoms of a converter failling,noise loss of speed? help me out guys.
thanks
thanks
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: trans woes
Sounds 1st like your TV Cable was not PROPERLY adjusted after your Flexplate install. And you probably didnt adjust it correctly at the track either.
Car: 84 camaro
Re: trans woes
how do you adjust it properly? i pushed in button on bracket and a plunger came out 1 notch,the thing the cable runs tru,but anyway it shifted perfect the 2 runs after that,b4 i adjusted it the cable had slack in it.but thanks for the reply.
anyway if it wasnt adjusted right i believe its way too late now,sounded like a cannon went off under car,just priced a rebuild price at 1,100 .im in the wrong bussiness i guess lol
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
