transgo reprograming kit
Old Oct 6, 2007 | 10:00 AM
monoply6's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
hi all need some advise please i have a transgo kit that came with my rebuild kit from raptor the paper work say you can use this kit to turn my valve body into a full manual if im right in what im reading does this mean i can do away with the tv cable this is because my mate is helping me rebuild my box he has done his own but he is worried about not setting the tvc correctly as he does not have one on his car and my nearest automatic gearbox garage is 260 miles away and they have never done a 700r4 before thanks for any advice
Old Oct 6, 2007 | 12:02 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: transgo reprograming kit
IDK if it actually intends to remove the need for the TV cable, but if its proper adjustment you are concerned with, there is one correct way to do it. Here is a link that will inform you greatly about it. Top left is the part 2 and part 3 pages. http://www.tvmadeez.com/article/index.php
Old Oct 6, 2007 | 01:10 PM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
hey thanks looks simple to do but does this kit really allow full manual control with out the need to buy a manual valvebody thanks
Old Oct 6, 2007 | 03:07 PM
Mikz86TA's Avatar
Im not 100% familiar with that kit. But from my understanding is that is retains full auto but allows for a complete manual shifting when you select low with the shifter. Stock the tranny is designed to upshift from 1st to 2nd at a certain speed even if the shifter is in Low/1. But you can hold 2nd all day. The backshifting is also only allowed at a certain speed in stock form. But the kit will correct that and allow for backshifts to 2nd and to 1st at any road speed.....which can be dangerous if you arent smart. IMO that puts a lot of wear on the clutchpacks if repeatedly done. There are 2 kinds of Manual VBodies. One allows for engine brakeing and the other doesnt. The one that doesnt probably allows for less clutchpack wear. I had a friend with an AOD Ford who put a MVB without engine braking. The drivability was pretty pleasant. You had to push a button to activate reverse. But the AOD didnt last.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:25 AM
italiano67
Sep 22, 2015 08:42 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
