84 camaro w/2.8 v6
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
84 camaro w/2.8 v6
what gear ratio was offered with the 84 2.8 V6 and do y'all think it would work okay with a carbed 305?
Car: 88 Firebird WS6
Re: 84 camaro w/2.8 v6
Most of the time (If not all the time) the v6 8th VIN S has a 3.42 open diff. It's the same/just as good if not better then rears in 305 carbed cars which it much milder (numerically lower) usually 3.08's in 8th VIN H cars.
The V6 rear will actually be better!!!
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Have you swapped a swaybar onto the rear yet? Most early v6 cars didn't come with them and swing around like they're on ice.
Car: 84 camaro s/c
Transmission: TH400
thanks guys, I believe this one has a factory rear swaybar. can't wait to try it out
84z96L31vortec
Aug 20, 2017 12:16 AM
