t5 from v6 to v8?
Old Oct 10, 2007 | 11:38 PM
migman's Avatar
Car: 89 camaro
Engine: 383
Axle/Gears: 10 bolt posi
t5 from v6 to v8?
I was wondering if you could use a t5 from a v6 and just change the bell housing. its the only used t5 i could get my hands on and thats after a year of searching. plus i like the 4.03 first gear.
Old Oct 11, 2007 | 01:09 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: t5 from v6 to v8?
this forum, please.
It can work but its more trouble than its worth. And with the higher gear it will be much weaker. Its not recommended at all.
Old Oct 11, 2007 | 07:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You don't need to change the bell. The V6 T5 will bolt up to the V8 bell housing. Hmm, maybe that is what you meant, change the 6 bell to an 8 bell.
The input shaft splines are different between the two. So need to get a V8 clutch disk made with a V6 center. Folks on here have done it, can't recall who made up the disk.
RBob.
Old Oct 11, 2007 | 08:46 AM
tyrvidar's Avatar
Car: 83 Z28, 88 Iroc
Engine: 305 CFI, 350 TPI
Transmission: 700R4, 700R4
Kevin, I always liked your car man, you have a mean ride. Haha has nothing to do with this post.
Old Oct 11, 2007 | 08:57 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Here is the conversion clutch:
http://store.summitracing.com/partde...5&autoview=sku
Old Oct 11, 2007 | 02:50 PM
migman's Avatar
Car: 89 camaro
Engine: 383
thanks for the info, i was wondering why it had 14 spline. so if i use a v8 bell housing, and the conversion disk, i should be okay? i wish i could have found but like i said, i thats all i could find, i have be looking for a used t5 since last september.
