Suggestions for Trans and Rear end?
Old Oct 25, 2007 | 10:27 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
I have a 92 RS with a 350, Hooker headers, True dual 2.50 inch pipes with 2 glasspacks. Recently My trans died on me, shift plate between 2nd and 3rd went out. I want to beef up my 700r4 and rear end before i put everything back in. What torque converter should i put in with that? I was also looking at 3.73 gears for the rear end.
What would I have to change out to do all this?
Old Oct 25, 2007 | 10:35 PM
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
Re: Suggestions for Trans and Rear end?
What kind of cam are you running?
If your looking to beef up the tranny, get a transgo shift kit and look into TCI's new constant pressure valve body. They say it keeps a constant 200psi or so of line pressure at all time and your TV cable is just used to adjust your part throttle upshifts, and its less that $300 retail. Looks like the way to go if you do a rebuild.
Seth
Old Oct 25, 2007 | 10:37 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
Whoops forgot to mention that -_-; Im already putting in a shift kit with the rebuild. And unfortunatly I have a stock cam...for now <<
Old Oct 25, 2007 | 10:56 PM
Bigseth's Avatar
Might as well put the stall in with the tranny out. It depends on what cam you go with but something around a 3000 would be good.
Old Oct 26, 2007 | 04:34 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
The cam will come later. I just need an idea of what would be a good torque converter and what all id have to change out to make everything work right.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
