6 speed problems???
Old Oct 16, 2007 | 02:25 PM
hardroc's Avatar
6 speed problems???
anyone having problems with 2 nd and 3rd in there t56 ... mine keeps poping out under normal driving conditions i dont rag my car out or anything sometimes it goes good and sometimes it just keeps falling out i have a b&m short throw shifter and the only thing i can figure is i am goin to have to replace the sychro's ... anyone have any input ... it worked fine up until now ...
Old Oct 26, 2007 | 04:59 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: 6 speed problems???
Does your B&M shifter have shift stops? I think some models did and some didn't. Anyway, if it has they are you sure they are adjusted right? If they are not set right it could cause the tranny to jump out of gear.
When I put in my Hurst shifter I did not set the stops right and they was exactly what happened until I adjusted it. If your shifter has the stops you may as well just back them all they way out since the T56 has internal stops.
Inside the tranny there is a plate with pits and a ball bearing with a spring that I believe holds it in gear. If it is jumping out the spring may be worn out. Just a guess.
jhawkeye
May 25, 2022 06:33 PM
nuggie
Aug 25, 2015 01:27 PM
InfinityShade
Aug 22, 2015 08:00 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
