s10 t-5 into an iroc?
Old Oct 30, 2007 | 07:20 PM
1dopehat's Avatar
Car: 1990 iroc sunday driver
Engine: 350 tpi
Transmission: auto
Axle/Gears: stock g92 stuff
im sure this has been asked a 1000 times but i need to know if a t-5 out of a 1999 s-10 with a 2.2 will work with my 90 iroc??? i know its a 350 and all and the trany prolly wont last long but...and is there anyway you can run the hydro clutch??? and what do i do about my electric speedo??
i have heard you can change the tail shaft over to the camaro style and run the v-8 bellhousing is this right or is there no way to hook the two together?
Old Oct 30, 2007 | 07:45 PM
Re: s10 t-5 into an iroc?
No it won't work. The shifter somes out in the wrong place. The S truck transmission would put the shifter RIGHT THROUGH THE MIDDLE of your radio.
Details...
All of these cars had the hydraulic clutch starting in 84. The S trucks started having it somewhere about the same time IIRC.
The electronic VSS or the cable drive is held in with one screw. Unscrew it, take out the one, put in the other, done. Takes less time to change over than it did to type the instructions.
Old Oct 31, 2007 | 05:16 PM
Shagwell's Avatar
Car: projects.......
a '99 S10, be it a 2.2 or a 4.3, won't have a T5 it'll have the little metric turd in it. If it were an older s10 with a t5, as sofa said, the shifter will be in the wrong place, AND it won't have the tq arm mount
Old Oct 31, 2007 | 05:56 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
ya but you could get the aftermarket relocation bracket that takes the torque arm off the tranny and connects it with the crossmember.
Old Oct 31, 2007 | 07:05 PM
And that would move the shifter back out of the dash and into the console .... how?
It won't work. Pretty much, end of story. The story ends with, it won't work.
Old Nov 1, 2007 | 09:15 AM
Shagwell's Avatar
yes, if you have an factory bird t5 which you can rob the shift rods and tailhousing off of so that you can relocate the shifter, then you can make it work. BUT, you now have more time/effort into it than just buying an f-body take-out, and, as I said, a '99 s truck would not be a T5, it would be a metric isuzu trans.
Also, the last few years of a T5 in an S truck would have had the smaller bellhousing bolt up like that of a mid to late 90's V6 f-body T5.
Old Nov 1, 2007 | 09:25 AM
1dopehat's Avatar
Engine: 350 tpi
Transmission: auto
k thanks guys i wasnt for sure i think ill just get a maro t-5 or go with the t56
Old Nov 1, 2007 | 10:06 AM
ryan91rs's Avatar
Transmission: 4L60
ya i didn't say it would take it out of the dash. lol. I was only helping half of the problem and giving no solutions. lol!
Old Nov 4, 2007 | 01:51 AM
Pat Hall's Avatar
Now you're on the right track.
Old Nov 4, 2007 | 01:58 AM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
all u have to do is get a shifter maid
Old Nov 4, 2007 | 08:11 AM
a shifter maid
What a mental image.
I WANT one of those!!!!
Old Nov 4, 2007 | 08:16 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
trust us, it's not that easy.
midge54
Sep 2, 2015 06:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Cacike
Aug 27, 2015 05:10 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
