89 rs camaro 2.8 v6 which trans
Old Nov 3, 2007 | 06:28 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
which transmissions will fit in these cars i know its a 700r4.will trans out of s-10 fit in this car?are there any others that will fit?isnt the bolt pattern on v8 trans different? thanks for all replies.oh did a search
Old Nov 3, 2007 | 06:49 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 89 rs camaro 2.8 v6 which trans
S10 transmissions from a 2.8 will work in your camaro. V6 60 degree engines (2.8/3.1/3.4) used in Camaros and Firebirds use a "metric" transmission bolt pattern.
If you use an S-10 transmission, you must also re-use your tailshaft housing for your torque arm mount.
Old Nov 3, 2007 | 07:45 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
thanks krisw for the help,later jimmy
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Dec 10, 2015 08:16 PM
92projectcamaro
Dec 8, 2015 12:25 AM
88rscamar0
Sep 23, 2015 09:08 PM
