axel play
Old Nov 5, 2007 | 06:43 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
axel play
ok so i noticed my car was gettin a little snakey in the rear end so when i got home pulled off the rear drivers wheel and brake drum and started to jiggle the axel shaft it dosent move side to side but in and out around 1/8th to 1/4" and when im driving it feels as if my sway bar is cracked off butt i know its not i checked all that stuff but i was just wondering if the play in my axel is normal and i should look elsewhere for my problem or am i on the right track? also what is the proper torque setting for my lug nuts i have them on at 110 foot pounds and need to be sure thats right
Old Nov 5, 2007 | 06:54 PM
simz28's Avatar
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
Re: axel play
I had this same problem on my camaro and it was causing the caliper to rub on the rotor. When i took the rear out, the c clips, which hold the axels in, made a bigger groove in the axels, giving it more room to move in and out. I swapped out the rear for another, since that one only had 2:73's. Hope this helps.
Old Nov 5, 2007 | 06:58 PM
Brennan's Avatar
Re: axel play
ok thank you it just so happens that i have another rear end in the garage, can i just swap the guts from each and fix my problem cuz the one i have is rough on the outside not sure if its a posi though is there a quick way to tell?
Old Nov 5, 2007 | 07:22 PM
simz28's Avatar
Engine: LS1, 5.3
Re: axel play
You should be able to swap the axles as long as the other rear is from a thirdgen and has the same nmber of teeth.
Old Nov 5, 2007 | 07:24 PM
Brennan's Avatar
Re: axel play
yeah its from another z and i might swap out the diff to if its posi cuz i think mines on the way out anyway
antman89iroc
36
Jan 31, 2016 08:42 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
rusty vango
Sep 29, 2015 02:44 PM
Bob88GTA
Sep 10, 2015 09:07 PM
