B&M megashifter problems
Old Nov 5, 2007 | 04:59 PM
Monica9's Avatar
Car: 87 Irocz
Engine: 5.7
Hey guys i just installed a new b&m megashifter and followed all the instructions on the manual. However i still cant get the shifter to shift smoothly, any ideas on what might be wrong?
Old Nov 5, 2007 | 05:10 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: B&M megashifter problems
what do you mean by smoothly? the megashifters are known for being rough coming out of park(i kinda like it that way). after that, there is gonna be a detent of sorts for all the gears. after you get to D, then it ratchets between all the gears up till reverse.
Old Nov 5, 2007 | 05:20 PM
Monica9's Avatar
Car: 87 Irocz
Engine: 5.7
it ratchets properly but its really hard to get it from park to reverse, almost need to use both hands to do so
Old Nov 5, 2007 | 05:22 PM
87zjeff's Avatar
that's actually kinda normal. had mine for about 3 years now and it is still rough from park to reverse.
Old Nov 5, 2007 | 05:25 PM
Monica9's Avatar
Car: 87 Irocz
Engine: 5.7
Really? i have been messing with this damn thing all day thinking something was wrong with it, just thought it shouldnt be like that, thank you for your help
Old Nov 5, 2007 | 07:02 PM
RebornFromAshes's Avatar
It will get better as the shifter wears a little.
As was previously stated, this is more of a design feature/defect of the Megashifter. I am sure a crafty person could modify the detent mechanism to make it a bit more reasonable to pull the shifter out of park.
Old Nov 5, 2007 | 07:14 PM
Monica9's Avatar
Car: 87 Irocz
Engine: 5.7
Can it be a sign that there is somthing wrong with the cable? There are no kinks in it and i installed it twice, to make sure it was on properly. I just dont want anything getting damaged cause any small install mistake
Old Nov 5, 2007 | 07:16 PM
87zjeff's Avatar
nah, don't sweat it. it will ease up after a while. the muscles in your arm will get accustomed to it like the difference between manual and power steering.
if you try to decrease the tension on the lever that provides the detent, it will also decrease the tension on the other positions.
Old Nov 5, 2007 | 07:29 PM
Monica9's Avatar
Car: 87 Irocz
Engine: 5.7
thanx, i will just continue the rest of the work on the car and hope the shifter gets a little smoother with time
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
