2nd gen 10 bolt posi swap to 3rd gen
Car: 87 camaro
Engine: 357 swap
Transmission: t5
I tried reading up on old posts and is it that its not possible or its very difficult? The one I'm looking at has ladder bars and coil over spring brackets. How hard would it be to mount the torque arm (I think I read it is difficult). How much wider is this rear end?
Re: 2nd gen 10 bolt posi swap to 3rd gen
All but impossible.
This belongs in the "If you have to ask...." category. If you knew what it would take, you'd be ANSWERING posts on here about it, not asking.
Width isn't much different; the 2nd gen is about 2" narrower on each side IIRC. Easy to make up with wheel selection or spacers. Among the least of the problems.
basically, it is more work than it is worth. Unless you are very good at custom fabrication and welding, it's just not cost effective. Even then you better be starting w/ a built 8.5"er that you got for free.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
