before i begin this t56 swap got a question or 3.
Old Nov 11, 2007 | 09:17 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
(1)i see that there is 4 sensor on the trans. 3 on the driver side and 1 on the passager side. wat sensor r wat? second (2) wat does this black tube that runs along the top of the trans? is that just a air vent or a fill thing?? (3)last question does the lt1 starter mount just like the t5 starter??? thanks, any info will help for a faster and better swap.
Old Nov 13, 2007 | 01:52 PM
LT1_IROCZ_KID's Avatar
Car: 1987 IROCZ
Engine: LT1/4 hybrid
Axle/Gears: Posi
Re: before i begin this t56 swap got a question or 3.
i have an lt1 and a t-56 im putting in. the starter on the lt1 is mounted on the engine, and doesnt (as far as i can tell) interfear with the transmission at all. the tube on the top i believe is for the dipstick. one of the sensors is a speed sensor. u may need to look at a wiring diamgram for a 4th gen
Old Nov 13, 2007 | 05:20 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
ok.....a t-56 does not have a dipstick!
the tube is just a vent.
the starter mounts just like any other sbc starter does....to the block.
the sensor on the passenger side is the back-up light switch.
the one at the top center is the skip-shift solenoid which wouldn't be used if put into a 3rd gen unless doing a LT1 swap also.
the one at the shifter mount is your reverse lock-out.
the small one near the back is you vss.
there is an article i believe it is in the FAQ forum that has all this info and then some. really good article.
Old Nov 13, 2007 | 05:48 PM
Car: 1987 IROCZ
Axle/Gears: Posi
hahahahaha ok man! my bad! thats wat i was told...but my mistake.
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
