Moser 9 Inch
Old Nov 13, 2007 | 10:23 AM
89IROCZDG3's Avatar
Car: 89 Iroc Z
Engine: 5.7 TPI
Axle/Gears: Moser 9 inch , 3.50 gears
Moser 9 Inch
I would like to put a Moser 9 Inch under my 89 IROC , but I am told that my disk brakes won't work. Why not?
Old Nov 13, 2007 | 10:55 AM
Re: Moser 9 Inch
Call Moser and ask.
You've just got the crappy Saginaw brakes anyway; not worth preserving, let aone moving to another component. Consider this your golden opportuinty to put some other kind of brakes on there that WILL fit, and that actually work. I've heard of people using Frod Exploder brakes on such setups which seems like a reasonable way to go.
Moser themselves might even be able to tell you what they set their rears up for. Just a thought....
Old Nov 13, 2007 | 12:04 PM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
Re: Moser 9 Inch
It just all has to do with the axle tube size. Moser uses 3" tubing, stock are smaller so it wont mount on to the housing end without modification. I cant be done with cutting and steel plates though just takes time
Old Nov 13, 2007 | 06:52 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Moser 9 Inch
We put this rear end in a buddy's '86 Trans Am over the summer... we used 4thgen LT1 disc brakes (discs, pads, calipers), and they worked pretty well.
Old Nov 13, 2007 | 07:01 PM
ChevyRS-305's Avatar
Re: Moser 9 Inch
my original axel had drums so when i bought my 9" i just called up moser and had them make the studs to 3rd gen factory specs and bought a disk brake coversion kit and installed it as if i has a stock axel swaping it from drums to disks. works pretty well
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
